Need help on engine swap
Old Mar 5, 2007 | 06:12 PM
honduh's Avatar
Default Need help on engine swap
hi i was wondering if anyone would know were i can get some good info on swaping a ls1 into my rx7 thx its a FD or 93-97 thx
Old Mar 5, 2007 | 07:09 PM
XtinctZ28's Avatar
Rehab is for quitters...
Try here: https://ls1tech.com/forums/forumdisplay.php?f=28 it is the forum called "Conversions and Hybrids - LS1 Engines in Non-LS1 Vehicles".
Old Mar 6, 2007 | 07:36 AM
RFERG43's Avatar
Go to www.torquecentral.com and check out the V8RX7 forum. Everything you want to know is there.
Old Mar 6, 2007 | 07:52 AM
dennyd's Avatar
You can get all the parts from Hinson super cars
Old Mar 6, 2007 | 10:09 AM
THE_SUPRA's Avatar
dude seriously...
Old Mar 6, 2007 | 10:34 AM
RFERG43's Avatar
Good luck on your swap. At first it might seem a little intimidating if you haven't done a swap before but if you search through the forums you will see its not that bad. You will need a bigger radiator, an electric fan, a fuel pump/ regulator, a larger clutch master, a shortened drive shaft. Search for those items and you will have most of your questions answered.
I've been driving my LS1/ FC for nearly two years now. I garantee you will love the car with an LS1 under the hood !!!!!
