Ls1=lt1
Old Mar 13, 2007 | 08:33 PM
baughb'smx6's Avatar
Default Ls1=lt1
Ok, I feel retarded for asking this, but, as far as mounting points/tranny are concerned, the bolting points are the same, right? I ask because I have a car all ready for teh LS1, but I'm having a little trouble getting the cash (long story), so I was going to try and just find a cheap LT1 until I could find an LS1.
Old Mar 13, 2007 | 08:47 PM
patgizz's Avatar
no, the engine mounts are different.
why not snag a 4.8 if you're low on cash? then itll be ready for the ls1.
Old Mar 13, 2007 | 08:59 PM
hpmotorsports's Avatar
Default like he said
get a 4.8 or 5.3 they have the same mounting points as a ls1 and everthing will interchange, plus they are cheap
Old Mar 13, 2007 | 10:49 PM
G-Body's Avatar
sawzall wielding director
The mounting points, transmission, and wiring are completely different. If you are short on cash pick up a 4.8L or 5.3L, they have the same mounting points, transmission and the wiring will be the same if you use the f-body coils, injectors, accys, and intake manifold. You should be able to easily pick up a long block for a 4.8L for under $1000.
Old Mar 14, 2007 | 12:22 PM
patgizz's Avatar
i see sub 80k mile 4.8's go on ebay regularly for under $300
the last one i watched, i got outbid at the last minute and it went for $215. look up lkqonline on ebay. sometimes they even come with brackets and the harness
