Transmisson will not shift after conversion
Does the stock pcm ground the coils only? Is there a fused 12 volt lead for the trans only?
Any help would be awesome.
Thanks
Elec
If you wired it in to another fuse box make sure that socket f2 of connector C2 that used to go to the truck fuse box has power. It is the large rectangular black connector that is not sealed.
Then I could find where I need to add the 12 volts to make this thing drive correct.
Thanks again guys!
Elec
The power for the trans comes through C 100 pin G.
