fuel pump question!
Old Mar 22, 2007 | 05:27 AM
daddykamp's Avatar
Default fuel pump question!
Will a fuel pump out of a 98-02 camaro fit/work in the tank of a 1994 camaro? I need to get rid of the v6 pump because the ls1 needs 60 psi and im only getting around 40 psi but im not sure if an ls1 pump will work, i know an lt1 pump would fit, does anyone know if an lt1 pump would do the job or do i need to have an ls1 pump? TIA
Old Mar 22, 2007 | 06:58 AM
Rick Speed's Avatar
all the pumps are the same.. sounds like you need and adjustable regulator
