oilpan ?
Old Mar 23, 2007 | 01:02 PM
lowapache's Avatar
Default oilpan ?
I have a 1957 chevy truck with a 78 firebird camaro front clip I am puting 5.3 I want to know what oilpan would work the best the truck,camaro or the gto
Old Mar 23, 2007 | 01:28 PM
bczee's Avatar
Since it is a Truck, the truck pans would work ok.. but how low is the truck.. if you are down to the ground.. then
CTS-V, as it has a shorter lower slump but is about 2" more in ground clearance than the Truck.
And then the F-Body, would be my next choices. F-Body maybe tight, depending on where you locate the engine (how far back you can go.) the lower slump is longer that the CTS-V and Truck.
But not the GTO, that is front slump.
Check the FAQ/Sticky for the Oil Pan Dimension (or S&P website).
Old Mar 23, 2007 | 01:41 PM
lowapache's Avatar
cool thanks
