Ls1 Third gen guys
Old Mar 26, 2007 | 11:10 PM
qualls86ta's Avatar
Default Ls1 Third gen guys
Im going to put a TH350 into my 3rd gen ls1 car, what crossmember do I need to use, can i use the stock from my 700 r4 or do I need to buy one, I need to know Im gonna do this in about a week, swap out my 4l60e for a th350
Old Mar 27, 2007 | 09:26 AM
ghettocruiser's Avatar
Might give Spohn a call... Are you going to still run the torque arm? If so you will need a way to mount that. TH350's dont have provisions for a torque arm...as far as I know.
Anyway, here is his TH350 crossmember/torque arm combo.
http://spohn.net/product.cfm?productid=1303
It doesnt say if it will work with the LS1 set up, but since the LS1 sits in about the same position as the regular SBC...it should work. Its pricey, but it will offer you a bolt on solution and adjustability.
Justin
Old Mar 27, 2007 | 09:36 AM
qualls86ta's Avatar
I seen that last night, i hope it gives more clearance for exhaust than the 4l60e crossmember
Old Mar 27, 2007 | 09:44 AM
Well...Im not real real familiar with auto trans clearances...especially with the TH350, so maybe someone else will chime in. Or do some searching. But I will tell you that the spohn crossmembers tend to take up some space for the exhaust.
You can always build your own... then maybe just get his toruqe arm and mount it on your x-member. Thats what Im getting ready to do, except I have a T-56.
Justin
Old Mar 27, 2007 | 05:19 PM
bygblok's Avatar
I bought a torque arm for my th350 conversion that has a plate that bolts up to the floor pan. The arm is probably two-thirds the length of the factory arm and is double adjustable which "should" help move my instant center back and hit the tires a lot harder. I'm not sure about the transmitted noise to the car but with spin-tech duals I'm not sure it'll make a huge difference anyway for noise. I'll need hearing aides in a few months anyway!!
Old Mar 27, 2007 | 11:13 PM
qualls86ta's Avatar
Where did you get it from?
Old Apr 1, 2007 | 03:05 PM
TJ's Avatar
TJ
id stay away from spohn if you are doing a set of headers on the car.
spohn x member is in the way.
BIG TIME.
