TT LSX into 3rd Gen
The rear suspension is all interchangable with the 4th gen cars (the 4th gen axle is slightly wider, but will still fit/ bolt in. you'll just need more backspacing on your rims)
you can buy all the engine mounts, etc.
4th gen gas tank will fit right in (get the plastic tank as the rubber neck is easy to trim. you need to shave an inch or 2 off the neck for proper fit)
the big limitation right now I'd say for the LS1/ 3rd gen swap is the exhaust, but since you're planning on a TT set up you'll need to make custom exhaust anyhow.
There's a thread or 2 on tubular crossmembers over on the 3rdgen.org, most people have good things to say about the Spohn tubular crossmember. You may want to consider one of these for more room/ clearance for your TT set up. Everyone is also saying there's a long leadtime to recieve the part. you may want to order early.
If you have any specific questions regarding installation on the LS1/ 3rd gen cars, let me know.
I hope this is helpful.
I'd stay with the stock gas tank, there really isn't a gain from using the 4th gen tank; you'll have to connect plastic to metal fuel lines if you do. As said above, several tranny crossmembers are available but it forces the exhaust around them and under the frame rails; this makes your exhaust hang pretty low. On thirdgen you can search for "Drews crossmember", he makes a crossmember that lets the exhaust go under it. If you remove the overflow and wiper fluid tank you should have room for a turbo and pipes, of course a battery relocation will help too.
Good luck.
I plan on doing a BMR tubular k-member and tubular front suspension. I've heard of people having clearance issues with the Spohn setup as far as the steering components go. Looks like I'm gonna go with the LSX block and LS7 heads.
I know that the Edelebrock carb style TB intake works with the LS2 heads, but what about the LS7 heads? Will it have to be massaged to match the rectangle port heads or do they make one that will interchange?
