6.0 into 92K15
Old Apr 2, 2007 | 07:43 PM
gonzo 6.2's Avatar
Default 6.0 into 92K15
Pulling 4.3 keeping OE 5sp.trying to figure out which flywheel I need,I am using a early long flange 6.0 crank.I think I need the early flywheel.Also does anyone know if the 2K camaro wiring harness alt.plug will work on a truck alt.?I think I will need to use a Fbody MAF not a truck maf.Any help would be appreciated.
Old Apr 2, 2007 | 09:08 PM
G-Body's Avatar
sawzall wielding director
The trans should bolt up if you use the early style flexplate from the 99-2000? long crank 6.0L.
You are trying to use a f-body harness on the truck motor right?
What about the computer what is it from and what year?
The f-body alt plug will physically fit into the alt, but I am not sure if it will work properly. The f-body alt`s use one wire on that harness that feeds the alternator a +12V signal through a resistance source(Either a resistor in the computer or a light bulb). All of the newer trucks that I have seen used 2 wires in that plug, the 1st is the same as the wire I just described, and the second just goes to a +12V IGN source. But I did see a 1999 6.0L truck that only used 1 wire like the f-bodies. So you may or may not need to add a second wire into that plug.
If you use a f-body wiring harness you need to either use a f-body MAF and IAT or make an adapter harness to use the combined truck MAF/IAT sensor.
Old Apr 2, 2007 | 09:38 PM
gonzo 6.2's Avatar
Thanks for sharing your experience 99-00 fbody harness worked on by waitfor me Jesse.I have a 2K truck PCM I plan to use.I do believe there is a 99-00 truck alt and a 01+,So i should be OK there with getting an early one.Thanks again
Old Apr 2, 2007 | 09:44 PM
gonzo 6.2's Avatar
Glanced at your site I really like the Camino,nice package and the same for the smoke'n hot bannana babe.
