Need help quick...pilot bearing question
Old Apr 9, 2007 | 08:43 PM
jimmyp's Avatar
Default Need help quick...pilot bearing question
Im doing some dyno testing of a 03 4.8L truck motor. The dyno input shaft is about .59" OD which is the same as the older GM manual transmissions. As close as I could measure the ID of the crank is 1.063". Where can I find a pilot bearing/bushing that will work? Part numbers would be great!
thanks guys, i will post up my dyno results here when I am finished to try and help us conversion guys determine the best setups for our conversion projects.
Old Apr 10, 2007 | 07:52 AM
cam's Avatar
cam
Cant give you measurements and not sure if the 4.8 is the same but I can tell you this much. I had a new pilot bearing that I never used from a previous build ( sb350 crate with t56 ) and it fit the LS1 crank fine.
Old Apr 18, 2007 | 12:52 PM
jimmyp's Avatar
thanks...found a bushing from an 80s truck and it worked fine
Old Apr 18, 2007 | 01:52 PM
Rodder's Avatar
Looks like most manual trans GM cars since 1946 use Motormite/Dorman/Help part #14650 for the pilot bushing. Includes LSX, SBC, BBC, straight 6's, V6's, Iron Duke 4 cyls, etc.. you can look up all of the applications on dormanproducts.com.
By Brett Foote | 2026-06-04 05:00:17
