Help!! Altenator Wiring
Choice Automotive in Alberta canada did my harness worked great
Since it is a f-body alt it should be an easy 1 wire hookup. You only need to connect terminal B on the alternator to a +12V resistance source. Theres more info in this thread https://ls1tech.com/forums/showt...ight=alternator
But basically you can go about it in 2 ways.
A. Connect a wire to terminal B on the 4 pin plug and then connect it to a 470 ohm 1/2 watt resistor and then connect the other side of that resistor to a +12V IGN+ source (IE coil wire).
B. You could also use the factory idiot light in your monte. On the original 305 alternator there was a brown wire that connected to the 2 pin connector for that alternator. It goes into the dashboard, to the alt idiot light and then to +12V IGN+. If you hook this wire up to the alt the idiot light for the alt will work just like it did from the factory.
