coil harness for ls1
Old Apr 15, 2007 | 07:45 PM
ChucksZ06's Avatar
Default coil harness for ls1
I tried search and came up empty...does anyone know if there is a part number for the harnesses for the coils? Thanks in advance.
Old Apr 15, 2007 | 09:44 PM
cnichols's Avatar
I've got a used set that I might be willing to sell you.
Old Apr 27, 2007 | 11:11 PM
martinsw's Avatar
Old info I had around on this is:
coil mtg bracket 12563288 or 12562864 from rockauto or gmparts direct ~ $9
Coil harness 15301401 ~ $ 50 each on gmpartsdirect
I found some from a fellow forum member like cnichols offered - saved quite a bit from buying new (maybe you already got some from him - but others might find the info good)
A note of caution - gm is notorious for changing part numbers - and I think the 98 may have a different pn, but should electrically work (just some physical fitment differences with coil brackets if put on center stud covers).
