Power Steering
Old Apr 19, 2007 | 09:45 PM
SySt666's Avatar
Default Power Steering
What is everyone using as far as the fitting on the power steering pump pressure port goes? I am to go from 6 AN to whatever the pump requires.
Old Apr 19, 2007 | 11:28 PM
bczee's Avatar
You can get a 16x1.5mm o-ring adapter to AN fitting.. I am using this on my Chevelle. You will have to use something like Russesll Powerflex Teflon line Braided Hoses to handle the high pump pressure. Normal Power steering hose can be used on the low side.
Old Apr 20, 2007 | 09:26 AM
67rsss's Avatar
THese are the parts I have on order for LS1 into 67 Camaro. I have a diagram of this drawn up on my fquick, it is also discussed in our swap thread. If you are going to build your own hoses, it is critical that you use a system rated for power steering use (like the Russel Powerflex line). All fittings must be steel! No aluminum in this stretch.
AER-FBM2608 $13.95 (1) Straight, Steel, -6AN to 16mm 1.5 male with o-ring.
$13.95 P/S Pump adapter
AER-FBM2965 $6.95 (1) Adapter, Steel, 11/16 inv Flair to -6AN
$6.95 P/S Gear adapter, pressure side
AER-FBM2964 $6.95 (1) Adapter, Steel, 5/8 Flare to -6AN
$6.95 P/S Gear adapter, return side
RUS-620421 $12.95 (3) Fitting, Hose end, 90 Degree, Power steering -6AN
$38.85 Power steering
RUS-632600 $18.88 (2) Hose, Powerflex, -6AN, 3ft
$37.76 Power steering hose
Even though you don't need the fancy line on the return side, we wanted the same look for both lines. You can save a little on the hose and one fitting if you use a barb and regular 3/8 fuel hose.
Old Apr 20, 2007 | 10:18 AM
Steve68's Avatar
Where did you get the fittings?????
Old Apr 20, 2007 | 10:40 AM
67rsss's Avatar
All part number listed are the Summit numbers, a couple fittings we sourced from other places, but when we started putting together the fluid hookup infor, I decided to list everything from one source, so I picked Summit as just about everyone has an account with them.
Old Apr 20, 2007 | 12:12 PM
Steve68's Avatar
Thanks
Old Dec 18, 2007 | 07:36 PM
Jeff Smith's Avatar
Thank you so much..I have been trouble to find the right fitting for my 2001 Camaro Rack to custom PS tank.
