ls1 swaps
ds, autometer gages, standalone pcm and harness, aeromotive reg. and fuel rails. that pretty much covers the basic stuff, did not use any of the stock lt1 dash gages, went with autometer, no ac, heater. its not as dificult as some believe, imo very much worth it,.
it's not even reporting the correct # of post viewings! How weird.... i helped a friend do it...
it basiclly bolted together... he used a stock LS1 car kmember, ect...
really the only non-stock thing about it is the wiring, and the fuel feed line.. everything else is just using LS1 parts...
oh, he already had an aftermarket hood with a lid setup on it... so that wasnt an issue... i suppose you would be trying to squeeze a 90 and filter in there if you didnt do that...
it's not even reporting the correct # of post viewings! How weird....oh, he already had an aftermarket hood with a lid setup on it... so that wasnt an issue... i suppose you would be trying to squeeze a 90 and filter in there if you didnt do that...
well, to bolt it in, you need the LS1 Kmember...
im sure there are some small bits and pieces i dont know about... like i said, i just helped him, he actually did the little stuff.. i was just there for the Kmember swap, and to wire it up.
i woudlnt put an ls1 in it.
i would put a bigger bore shortblock so that you can run the newer wideport heads... not only the L92s, but all of the future GM heads
As far as everything else, you need a LS1 Transmission, and LS1 Steering Rack. You have to get a 1999 and up Corvette Fuel Regulator to convert it for the Fuel Rails. I managed to get ahold of some conversion Mounts to mount a LSX Block to my LT1 K-Member. I paid $40 shipped for them, and they came with all the hardware. Throttle Cables are goin to be custom for me, I have to Extend them.
Mine is a little bit different setup, but still basically the same.
I prefer to use the LS1 Tranny cause it bolts up in about 7 different spots, it's enclosed and everything is already setup for it.
That and I got mine for $165..
