402 LS2 in a 1995 Z28
Old May 1, 2007 | 10:56 PM
the_merv's Avatar
Default 402 LS2 in a 1995 Z28
For any of you interested in this swap, it's on now..
Today I went up to the guy that Tunes all the LSX's here, and we put in the Base Tune. I plugged in the Harness, the PCM, grounded it where it needed to be, and as soon as we turned the key, the Fuel Pump kicked on, everything lit up like normal, and we tuned it. It will be adjusted when it's broken in. We set it up to 90% capability compared to his other Tunes on similar Engines, basically right now it's tuned to atleast 550+hp
It's got Fuel, everything checks out, so it's all good now. I got to get this Engine in..
Everything with this project I have built. I took the time to research and build the Harness, I am putting in all the required parts for this swap, and I am building the Engine. The Tranny is going to be professionally built, but I am doing an the other work.
The specifics are in my sig..
Here is some pics..
Old May 2, 2007 | 12:04 AM
daniel6718's Avatar
i guess
looks weak though
Old May 2, 2007 | 12:34 AM
the_merv's Avatar
weak compared to what..
Old May 2, 2007 | 12:43 AM
Gen3Benz's Avatar
sweet.
what piston/rod combo you gonna use?
Old May 2, 2007 | 12:59 AM
the_merv's Avatar
Mahle 12cc flat tops with reliefs, Eagle Forged H-beams, Eagle Forged 4" crank.
