A/C & Cooling Fan Connections
I have read the "sticky" on the fan wiring diagrams. This was very helpful. I also posted a question, but I am not sure anyone will see it since the post is so old.
My question is, what is recommended for aftermarket A/C systems like Vintage air? Also, what is the difference in the PCM between Low and High? Are the two set points in the computer? Are both programmable?
If I have the PCM controlling the fans as diagramed, should I tie the A/C into the PCM or just start the fan directly? Should I start one fan or both fans?
What does Red 17 and Red 43 on the PCM do?
Thanks.
Phillip
