Belt question
Old May 10, 2007 | 10:57 AM
Brandon Smith's Avatar
Default Belt question
Alright I have a 1967 camaro that my LS1 is going in and have the ATS mounts in there with the A/C gone and everything else is there. Did a search and couldnt find an answer. What belt can I use now that the A/C is gone. I mean i know that it has to be shorter and I have a belt that is shorter to bypass the PS would that work? Secondly if so can I get this belt at a local auto parts store instead of having to order the thing. thanks in advance
Old May 10, 2007 | 11:04 AM
Darracq's Avatar
Just measure what you need and go to the parts store, thats what i did.
Old May 10, 2007 | 11:06 AM
67rsss's Avatar
The A/C on an LS1 has it's own belt. The goodyear serpentine for your motor is GTR-4060790 Serpentine belt, 6rib, 79 inches, and costs $24 at Summit.
Old May 10, 2007 | 03:23 PM
jim57's Avatar
Default How much tension?
When measuring,in what position should the tension pully be?
Jim
Old May 10, 2007 | 03:35 PM
67rsss's Avatar
The A/C is a seperate belt. Removing the A/C does not change the need for a 79 inch belt on the F-Body acc. Depending on what donor you used, you may need a differnt belt. Buy the main belt for the donor. You do not need a different length belt if you removed A/C on an LS1.
