Fuel Pressure
Old Apr 25, 2003 | 10:26 PM
Heimbig's Avatar
Default Fuel Pressure
I am putting an all aluminum 5.3 vortec into a vehicle. The donor is a 2003 Trailblazer. The fuel system is the same as any 5.3 or LS1. Is there a pressure regulator built into the system at the intake. Does anyone know what PSI is would be set for?
Old Apr 26, 2003 | 07:07 AM
Speartech's Avatar
9 Second Club/LS1TECH Sponsor
Default Re: Fuel Pressure
As long as nothing has changed on this new engine, you should be all set since the truck intakes have the fuel pressure regulator built in, and have a fuel feed AND return line. The regulator is the round thing on the rail with the small vacuum line going to it. The pressure is set to 58 psi. The larger line is the fuel feed and the smaller line is the return.
__________________
91 Z28 LS2 408CI, LS9 Supercharger, LPE GT7 cam, Yank3000, 3450 raceweight.
Latest numbers: 9.71 ET, 141.42 MPH, 1.40 60' , 610 RWHP Mustang Dyno
www.speartech.com
