What belt do I need?
Old May 14, 2007 | 07:02 PM
Indyjc's Avatar
Default What belt do I need?
While I'm waiting for my money tree to grow. Doing some research what belt do I need for an ls1 no a/c f-body acc? Did a search and came up empty. Thanks
Old May 14, 2007 | 07:47 PM
Scooter70's Avatar
You can use a string to measure. The last digits of the belt part # is the length. ie XXX71 = 71 inches long.
Old May 14, 2007 | 08:03 PM
G-Body's Avatar
sawzall wielding director
The belt will be the stock length. All of the f-body, vette, and truck LSx motors use 2 belts, one runs the A/C and the other belt runs everything else. So if you remove the A/C you only need one belt and the length stays the same.
Old May 15, 2007 | 07:52 AM
67rsss's Avatar
Serpentine belt, 6rib, 79 inches
GTR-4060790
Summit $24.
Goodyear Serpentine Belt: Gatorback
Part Number: 4060790
Kragen/Checker $29.99
Summit is hair cheaper. Same belt. The A/C belt is a four rib 41" belt for stock A/C location. If you add A/C later using an aftermarket relocate kit, it should specify belt length.
Old May 15, 2007 | 10:34 AM
Mr.Hatch's Avatar
Are you still running power steering?
I used a 52.5 inch 6 rib on mine - No AC - no power steering.
