Would it be worth it to ?
Old May 15, 2007 | 11:50 PM
Dstryr's Avatar
Default Would it be worth it to ?
First off is it possible to install a posi rear-end out of a 1995 camaro ss into a 1971 z28 clone? I need more gearing but figured if it was possible to just swap in a newer unit out of a parts car.
So if it is possible swapping in the new rear end? Another advantage other than the price is that it comes with disc brakes.
Or trying to find a posi rear end with 373's for a decent price.
Old May 16, 2007 | 07:15 AM
76LQ9TA's Avatar
The 95 axle is weak. The 2nd gen 8.5" rear axle is better. I installed the rear disc brakes from a 2002 firebird in place of the drum brakes on my 78 TA. You need to space the brackets back about 1/4". The disc brakes need a 16" rim minimum though. You will also need to change the master cylinder and drill a new hole in the brake pedal. You should be able to get 3.73 gears cheaper than the 95 axle. I bought the rear brake parts new from gm for around $250. Go to the dealer and get a parts list for a non-traction control rear axle.
Old May 16, 2007 | 05:38 PM
Dstryr's Avatar
Hmm I guess now to find a posi rear end for a 71 . WIsh me luck.
Old May 16, 2007 | 06:04 PM
Deerhunter-Z28's Avatar
not worth it
Old May 17, 2007 | 09:47 AM
'JustDreamin''s Avatar
As mentioned earlier, your current rear is stronger than the late model stuff (8.5" vs 7.625").
It'll be much easier to just buy the parts you need and put them in than to find the exact rear you're looking for. However, setting up a rear is some specialized business, so you may need to have somebody knowledgeable set it up.
You might be able to score a used posi rear with the gears you need for less money, but how long will it take to find what you're looking for and what condition will it be in? And will you actually spend less money?
If you put parts in yours, you will know whats in there, and what condition they're in.
'JustDreamin'
