about to attempt the swap...
Old May 16, 2007 | 01:37 AM
blahster's Avatar
Default about to attempt the swap...
of my 99 LS1/A4 into my 95 LT1/A4 Camaro.....
i know i need to address the fuel issue...
i am going to swap out the dashes, possibly the fuel lines and tanks, and definitely going to drop both engines out via the k-member routine...and i am definitely going to try to keep as much of the wiring intact and swap it as i can...
Any other tips/isseus i should be aware of?
Old May 18, 2007 | 12:26 AM
blahster's Avatar
So i have a few questions...
i see in the stickies about the wiring stuff...but one question that arises...
are the fuel pump plugs by the tank the same through-out the years or do they differ? I took out the tank/fuel lines from the LS1 to put in my 95...and i had that question about those connectors.
I think i have a decent handle on the other wiring...i.e. fans, etc...Don't need cruise/trac control/..A/C will come later....
i just need to get this thing on the road as soon as i can...we are down to 1 vehicle for 3 people...that kinda sux....lol.
Another question...will the ABS lines for the LS1 match up to the lines for the LT1? What would need to be done to retain the ABS????
Also the plugs on the passenger side by the PCM, can they just plug into the current plugs on my 95?
Any help is GREATLY appreciated! Thanks!
Benny
