vacuum sources?? Evap?
Old Apr 28, 2003 | 08:21 AM
67ls1CamaroProject's Avatar
Default vacuum sources?? Evap?
Can anyone tell me where to look for all the vacuum sources. One easy one was the brake booster. I do not have power brakes yet. What is the best way to plug this? Found another small line in the harness and capped it off. Are there more? Can not really hear anymore. What about the Evap line going to the manifold. I have the solenoid disconnected. Is that sufficient or should I plug the manifold in some way?
Old Apr 28, 2003 | 08:42 AM
Magnus's Avatar
LS1TECH Sponsor
Default Re: vacuum sources?? Evap?
I removed evap completely for my swap. What I did was just use a rubber cap over the tube that comes from the TB for the solenoid.
I went to pep boys and you know they have that red HELP section, well I found this one package that had various vacum plugs, they go over the pipe.. and one fit perfectly.
