Part numbers for fuel system
Old May 22, 2007 | 01:19 PM
69MyWay's Avatar
Default Part numbers for fuel system
I think this will cover what is needed if you have a 5/16" and 3/8" hard line on your car and plan on running a 99 and up Corvette fuel filter/reg. Russells now makes a EFI GM quick connect to -6 AN fitting.
You will also need the Dorman 12" male quick connect to slip into the output side of the filter.
All hard lines require a 37 degree flare on them after sliding over the nut and sleeve. The same nut/sleeve is used on the 5/16 as 3/8 line - you just have to flare the line out larger.
2 - 640850 3/8 fuel line adapter (connects to the rail and input on filter_
1 - 640860 5/16 fuel line adapter (connects to the return on filter)
2 - 660650 -6 sleeve (two per pack)
2 - 660570 -6 nut (two per pack)
1 - 660353 -6 union
2 - 613170 -6 90 degree connector (could also use straight lines)
1 - 632060 6' of -6 braided line
The quick connects look like this:
http://store.summitracing.com/partde...5&autoview=sku
All of this totals up to about $130 + the Dorman Products adapter and the fuel filter/regulator making the filter to engine line just north of $200.
Old May 23, 2007 | 08:41 AM
nitrovette's Avatar
thanks chris this should help alot of guys out.
