Corvette vs. GTO front accessories
Old May 22, 2007 | 04:05 PM
Jemo's Avatar
Default Corvette vs. GTO front accessories
I've found some info about how f-body and vette accessory pulley's are not interchangeable. Does anyone know if the alternator and bracket from a LS1 vette will work on a GTO LS1?
Old May 23, 2007 | 03:31 AM
Chris442's Avatar
Needs to finish car
In a word, no. The GTO stuff is spaced out farther than the vette; stuff from an f-body will work, though. You could always space the bracket out from the motor, but it needs to move a pretty good distance off on the head (.800" if I remember right.)
You could always use a vette balancer, too.
Basically there are three depths, from nearest to block to farthest: Corvette/CTSv, f-body/GTO and truck. So long as you have one depth for all accessories you're in good shape.
For example, on the '68 Camaro I am building if has an f-body alternator and PS pump, but a GTO A/C compressor.
As a side note, the CTSv is arranged like the f-body and GTO, but closer to the block like vette stuff.
Old May 23, 2007 | 08:35 AM
Jemo's Avatar
Thanks. That helps. My problem is that I'm probably going to have to relocate my a/c compressor and alternator to a high mount so they don't hit the frame. Know of any options that are cheaper than buying a fancy pulley set from March or others?
Old May 23, 2007 | 02:31 PM
5150mechanic's Avatar
The CTS-V acc. are pretty nice but the alt/ ps-ac pump are pretty exp. Brackets are cheap though. A nice and tight arangement.
Old May 23, 2007 | 02:34 PM
Oh, and try www.carshopinc.com . They have some what affordable set-up.
