s-10 radiator
Old Jun 4, 2007 | 01:15 AM
GraphicNature's Avatar
Default s-10 radiator
looked through the s-10 thread already but i just give up but so could you tell me what type of radiator i should use its a 99 ls1 in like a 95 s-10 thanks for everyones help
Old Jun 4, 2007 | 07:28 AM
Jhankinson's Avatar
4.3l aluminum radiator for a 4.3l S10 or blazer. works great.
Old Jun 4, 2007 | 02:26 PM
just a standard 4.3 or one from a 4wd or a blazer work better or are they all the same thanks
Old Jun 4, 2007 | 07:02 PM
eagleuh1's Avatar
I used the standard radiator that came in my 96 S10 4x4 Blazer, works great so far. Maintains around 195 to 215 D Far. I've seen somewhere the Blazer radiator is a thicker core. Don't know for sure though.
Old Jun 5, 2007 | 01:07 AM
what kind of fan setup are you running
Old Jun 5, 2007 | 01:22 AM
eagleuh1's Avatar
2 12 inch fans from advanced auto run by the computer. I set up 2 extra relays on the under hood fuse box to run them. so far only one fan comes on. I used the plastic ties through the radiator for right now. Maybe build alum shroud later.
