mounting PCM in a fox
Old Jun 14, 2007 | 10:05 PM
nuckifuts's Avatar
Default mounting PCM in a fox
i was being a bit lazy and tired of dealing with wires but i finally mounted my PCM. i wanted it inside the car for cleanliness under the hood so i put it above the blower motor. i had to remove the 'outside air' part of the blower motor case so the ac will only suck air from inside the car (which i always have it on max anyway) but it was the only way i could find enough space and harness slack for it to work. i hope this helps.
and it will be at the track next saturday, hopefully on spray
Old Jun 15, 2007 | 06:04 PM
vanilla89's Avatar
i got mine in the kickpanel where the stock pcm was.but the dash whould have to be taken out to change the pcm,it's a tight fit.
