98 3 wire temp sensor connector
Old Jun 15, 2007 | 10:00 PM
RE AND CHERYL's Avatar
Default 98 3 wire temp sensor connector
I've noticed many of you looking for 98 only three wire temp sensor connectors. Tonite I was looking on Ebay and found THIS
I sent the a question to make sure I would get a 98 specific connector.
Re'
Old Jun 16, 2007 | 04:29 AM
daniel6718's Avatar
yes go to your local junkyard and get a TPS connector from any late model gm car...its the same...
Old Jun 16, 2007 | 07:24 AM
AWSOME! I never knew that. I assume the 98 temp sensor will work with the LT1 gauges with no problem.
Re'
Old Jun 16, 2007 | 12:41 PM
01WS6/tamu's Avatar
yes it will
Old Jun 16, 2007 | 05:37 PM
dsrour's Avatar
What is the output of the 3rd wire. Is it a themistor? Will it work w/ 60's era gauges? Thanks
Old Jun 17, 2007 | 01:49 AM
daniel6718's Avatar
it has 2 output wires...i couldent get mine to work in my 94, so i bought another sensor and got another plug(2 wire, from any late model gm collant sensor) and put it in the back of the [passenger head..you cant run the pcm and gauge from the same wire for some reason...ythe 98 didnt work for me, so i use 2 sensors now
