67RSSS' project spreadsheet
Old Jun 28, 2007 | 09:19 PM
67rsss's Avatar
Default 67RSSS' project spreadsheet
We promised to post this when the car was running. It is also posted in the long thread, but is pretty far back there. It isn't a very big file, and is on a free hosting site. It is an excell spreadsheet and has the cost, part number and source for everything we had to buy....
http://files.filefront.com/LS1+Swap+.../fileinfo.html
Old Jun 28, 2007 | 09:29 PM
Rantheman's Avatar
I could not get it to work
Old Jun 28, 2007 | 10:16 PM
enganeer's Avatar
I saved it to my computer and opened with Excel.
Old Jun 29, 2007 | 04:55 PM
67rsss's Avatar
Has anyone else gotten it to work? If not, does anyone know another free file sharing site?
Old Jun 29, 2007 | 05:04 PM
enganeer's Avatar
All I did was save it to my desktop and open with excel. Nothing weird to do and worked fine. Here is a copy and paste if 67rsss does not mind me posting it.
1967 RS/SS Camaro Running Tally for Phase I: $18,865.50
LS1 Swap Only: $12,383.00
Qty Price Ext. Price Part No. / Description Additional info
1 $3,900.00 $3,900.00 LS1/T56, 02 TransAm Performance Auto 2002 LS1/T56, LS6 block
1 $505.00 $505.00 shipping for motor Performance Auto
1 $0.00 $0.00 Program computer Performance Auto
1 $150.00 $150.00 Radiator and fans Performance Auto
1 $335.00 $335.00 Modified Oilpan Street&Performance 285 Core charge
1 $95.00 $95.00 Motor Mount Adapters Street&Performance VERY solid use with 71 Chvle 307 mounts
1 $218.00 $218.00 LS1Air Cleaner 3" filter Street&Performance Filter and plate.
1 $0.00 $0.00 3pin MAF Street&Performance 140 core charge, refunded on return of old MAF
1 $37.00 $37.00 Polished 3pin MAF adapter Street&Performance Maf to TB
1 $32.00 $32.00 Screw in IAT Street&Performance Fits S&P housing
1 $335.00 $335.00 Shifter Relocate Street&Performance Mcleod, 2.3 inch forward
1 $160.00 $160.00 Cross Member and mount Street&Performance Application specific
1 $78.00 $78.00 Slave Cylinder mount plate Street&Performance Black
1 $61.00 $61.00 Throttle Cable Street&Performance Lokar braided
1 $40.00 $40.00 Throttle Cable clamp Street&Performance Nicer than factory clamp
1 $35.00 $35.00 Power Steering adapters Street&Performance 5/8 flare, 11/16 inv flare to -6AN
1 $555.00 $555.00 LS1 swap Headers Street&Performance Coated
1 $100.00 $100.00 Fuel line from eng to frame Street&Performance Braided
1 $168.00 $168.00 Fuel filter, reg 99 Corvette Street&Performance Includes swagelock fittings
1 $20.00 $20.00 Collant sensor adapter, 1/2 14 Street&Performance Need to adapt to head
1 $77.00 $77.00 Thermostat Housing Street&Performance 15 degree angle
1 $1,150.00 $1,150.00 Custom Stainless Fuel tank Rock Valley Includes pump and straps
1 $310.00 $310.00 Cable X adapter Atrol/Abbot Drive cable is 3' long.
1 $450.00 $450.00 Rebuild Harness Speartech Includes Relays and Fuseblock
1 $14.00 $14.00 AER-FBM2608 Summit Straight, Steel, -6AN to 16mm 1.5 male with o-ring.
3 $13.00 $39.00 RUS-620421 Summit Fitting, Hose end, 90 Degree, Power steering -6AN
2 $19.00 $38.00 RUS-632600 Summit Hose, Powerflex, -6AN, 3ft
1 $63.00 $63.00 RUS-632080 Summit Hose, Proflex, -6AN, 15ft
1 $14.00 $14.00 EAR-100034ERL Summit Aluminum Fuel line, 3/8in Diameter, 10ft.
2 $8.00 $16.00 SUM-2200077B Summit Fitting, Hose End, Tube adapter, 3/8 to -6AN (m)
2 $12.00 $24.00 EAR-922106ERL Summit Fitting 90 deg, -6AN (m) to 1/4NPT (m)
6 $5.00 $30.00 SUM-221301 Summit Fitting, Hose end, -6AN (f)
1 $9.00 $9.00 SUM-G1881 Summit Clamps, Hose, 0.375 in
1 $56.00 $56.00 CSI-931R Summit Catch can
2 $34.00 $68.00 CSI-651R Summit Brackets for can
1 $15.00 $15.00 GTR61099 Summit Lower Hose
1 $12.00 $12.00 GTR61609 Summit Upper Hose
1 $24.00 $24.00 GTR-4060790 Summit Serpentine belt, 6rib, 79 inches
1 $32.00 $32.00 HUU-1630040 Summit Shift ****
1 $40.00 $40.00 DER-16759 Summit Adj Fan Controller
1 $80.00 $80.00 DAK-SGI-8 Summit Tach Adapter
8 $4.00 $32.00 BCH-4205 Summit Bosch Platinum plugs
1 $65.00 $65.00 6cyl pedal assy Ebay/Tamraz Need Cable type accel pedal for LS1 throttle cable.
1 $35.00 $35.00 Idler pulley Kragen/Checker Replace while out…
2 $5.00 $10.00 71 Chvl 307 motor mounts Kragen/Checker Part number 2142, use with S&P plates.
1 $50.00 $50.00 Tensioner Assembly Kragen/Checker Replace while out…
1 $40.00 $40.00 Misc wire and connectors Kragen/Checker little things…
1 $60.00 $60.00 New fluids, filters Kragen/Checker Oil, P/S, Coolant, Trans
1 $18.00 $18.00 Spare set of platinum plugs Kragen/Checker Had rich condition, wanted to compare two sets...
1 $265.00 $265.00 Equus 3130 Scan tool Kragen/Checker Handy already
2 $108.00 $216.00 AC Delco O2 sensors Kragen/Checker AFS97 (Short) and AFS98 (Long)
1 $55.00 $55.00 Custom Shift Boot Lightning Auto Customs Prototype, Black with Burgundy stitching
1 $200.00 $200.00 Custom Shift Boot Plate Dale Tenny Enterprises Aluminum Plate
1 $570.00 $570.00 LS7 Clutch with LS2 flywheel SDPC Also new slave cylinder, bolts, and pilot
1 $152.00 $152.00 Remake driveshaft, balance, u-joints AA Driveline Same Day Service!
1 $55.00 $55.00 Magnecor Wires 85259 Ligenfelter has 45 degree boots! Red only for 8.5mm
3 $15.00 $45.00 New Caps Whitaker GMC Oil cap, P/S cap, Rad cap
1 $50.00 $50.00 Misc Hardware Orielly/Menards/Do-It Misc new screws, clamps, bolts
1 $1,080.00 $1,080.00 Perf Alignment and Exhaust BeeLine SS Dual exhaust with X-pipe
0 $0.00 $0.00
1 $339.00 $339.00 IDT-1120680010 Summit Ididit Column
1 $96.00 $96.00 IDT-2207310020 Summit Ididit Steering wheel adapter
1 $95.00 $95.00 IDT-3000054340 Summit Rag Joint
1 $145.00 $145.00 GRT-1178 Summit Steering Wheel
1 $17.00 $17.00 GRT-5649 Summit Adapters/horn button
4 $38.00 $152.00 KYB-KG4515 and KG5524 Summit Shocks
1 $160.00 $160.00 CEE-2101 Summit Slapper bars
1 $120.00 $120.00 CEE-3112 Summit Subframe Connectors
1 $51.00 $51.00 CEE-7025 Summit CE wedge plates
1 $15.00 $15.00 CEE-7024 Summit Snubbers
1 $55.00 $55.00 GMK-4011-410-67 Summit Outside Mirrors
1 $25.00 $25.00 SUM-G7900 Summit Driveshaft loop
1 $640.00 $640.00 67RS Console and Gauges Ebay Great deal!
1 $145.00 $145.00 Weatherpack Kit Ebay Great connectors!
1 $320.00 $320.00 Deluxe Seatbelts Hot Rod Factory Incorrect seatbelts in car.
1 $150.00 $150.00 Door Hinge, hood hinge Hot Rod Factory This is what started the whole thing!
1 $25.00 $25.00 rso10 Hot Rod Factory fender adapters
4 $8.00 $32.00 rso61 Hot Rod Factory Limit switches
1 $35.00 $35.00 rso62 Hot Rod Factory limit switch brackets
1 $10.00 $10.00 rso24 Hot Rod Factory Headlamp bushing kit
1 $260.00 $260.00 s187 Hot Rod Factory Mono leaf kit
1 $50.00 $50.00 m214 Hot Rod Factory Rearview Mirror
1 $140.00 $140.00 Steering Gear Kragen/Checker Cardonne 276509 2 1/2 to 3 turn, Lares 972 same.
1 $200.00 $200.00 Rebuild brakes/ rear Kragen/Checker New drums, cylinders, combi-kit
1 $20.00 $20.00 Universal Washer pump Kragen/Checker New wiper motor doesn't have pump…
1 $20.00 $20.00 New taillamp bulb holders Kragen/Checker rebuilding rear body harness
1 $189.00 $189.00 RS-21RL Ricks First Gen Pair Headlight Door Motors, they do not fit well.
1 $85.00 $85.00 _6705 Ricks First Gen Gauge Conversion Harness
1 $10.00 $10.00 RS-64 Ricks First Gen Limit switch bolts
1 $3.00 $3.00 HW-63 Ricks First Gen Limit switch bracket botls
1 $23.00 $23.00 CG-45 Ricks First Gen Temp sender and wiring
1 $10.00 $10.00 WB-45 Ricks First Gen Washy Jar kit
1 $10.00 $10.00 WB-3 Ricks First Gen Washy Jar Bracket
1 $2.00 $2.00 WB-40 Ricks First Gen Washy jar screws
1 $6.00 $6.00 FWG-1 Ricks First Gen wiring gutter
1 $7.00 $7.00 EP-134 Ricks First Gen Battery Junction
1 $299.00 $299.00 WB-67 Ricks First Gen Wiper Kit with delay, modern, modify switch to work.
1 $209.00 $209.00 CDP-32 Ricks First Gen 6000 redline Tach
1 $40.00 $40.00 GC-4 Ricks First Gen SS Gas Cap
1 $90.00 $90.00 PK-30 Ricks First Gen RS Backup light kit
1 $34.00 $34.00 EMB-724 Ricks First Gen Template
4 $17.00 $68.00 TR-24 Ricks First Gen Rally caps
4 $5.00 $20.00 TR-57 Ricks First Gen Screws for caps
1 $15.00 $15.00 CP-45 Ricks First Gen Console bracket
1 $80.00 $80.00 CC-2701 Ricks First Gen SS Floor Mats
1 $33.00 $33.00 IN-6101 Ricks First Gen Package tray
1 $4.00 $4.00 IN-21 Ricks First Gen Dome lens
1 $10.00 $10.00 IN-22 Ricks First Gen Dome base
1 $14.00 $14.00 77043 Ricks First Gen Dome harness
1 $14.00 $14.00 CP-50 Ricks First Gen Console clips for seatbelts
1 $4.00 $4.00 IN-1 Ricks First Gen Seat bumpers
1 $2.50 $2.50 WS-60P Ricks First Gen Hood Bumpers
1 $15.00 $15.00 WB-7 Ricks First Gen Washy nozzles
1 $6.00 $6.00 PL-20 Ricks First Gen License lamp
1 $3.00 $3.00 WS-49 Ricks First Gen License lamp gasket
1 $625.00 $675.00 Front Disk kit (72 Chevelle parts) Inline Tube Fits 14" wheels, include spindles and 9" smooth booster
1 $275.00 $285.00 Hardline conversion for disk, clamps Inline Tube All Lines, hoses and clamps needed.
1 $399.00 $399.00 Tubular upper control arms Speed Tech Geometry corrective
1 $30.00 $30.00 Tubular Tie rod sleeves Speed Tech Cool Looking
1 $239.00 $239.00 Poly Front end kit P-S-T Standard kit
1 $90.00 $90.00 Poly Body Mounts P-S-T In Black
2 $27.00 $54.00 Inner tie rod ends NAPA Needed them.
1 $12.00 $12.00 New oil siphon line for gauge NAPA Copper
2 $38.00 $76.00 Push Bushings and Balljoints NAPA NorthCountry Really has gone up in price!!!!!!
0 $0.00 $0.00
