LSX into 2000 S10???
Some examples: The front accessory drive on your 4.3 will work on a 350. But the LS1 is completely different, meaning you need all new accessories (either C5 / C6 or I've seen truck accessories made to work).
Oilpan: The cast aluminum pans available for the LS1 series motors don't fit without either modification of the pan or the crossmember. 350 pans are available that just bolt in.
'JustDreamin'
http://media.putfile.com/Joyride-in-a-10-second-Syclone
The Vortec SBC motors use a similar CPI setup as your existing V6 uses (has 2 more "injectors" on the spider). Which is a potential flaw.
LT1 is a pain in the butt. Ever try to change plug wires? That's a 4 hr job. And the Vortec heads flow about the same (or better) as the LT1 heads. Reverse cooling setup is a pain to keep all the air out of.
Originally, I was going to use a Vortec V8 for my conversion. Then I figured out that the CPI injection setup was a complete dead-end. It's good for somewhere around 300 to maybe 350hp worth of fuel and then you're out of fuel, and there is no upgrade (it uses a goofy "spider" system instead of individual injectors). So, I decided upon the LSx platform. After I was mostly done with the coversion, I learned that some folks had figured out the fuel system problem. Turns out Mercruiser uses the same basic CPI system, but uses individual injectors instead of the spider. So, if you change to a different manifold base, you can run individual injectors, allowing you to add enough fuel to support more power.
Anyway, that'd be my recommendation. Go with a 5.7l Vortec motor from a truck. I'd love to give you a link, but I haven't got any....
'JustDreamin'
