Temp and Oil sender question
Same with the water temp, its a 2 wire, where is the second wire going, ground?
BTW.....this is for my carclubs Pinks car. Should be there the same day you guys run yours in KC
Help please.
Based on the temp it is 99 or newer wiring. The temp sensor is serial data, effectively a sensor wire and a ground.
I am not sure about the oil pressure, all the diagrams I have seen are single wire, maybe GM updated the later models to a 5v reference oil pressure sender? Ground, 5v reference power, and sensor output?
What are you installing the LSx into?
Re'
Got the temp working, just used the driver side hole in the head and a 6 liter sender. Ground and signal to gauge.
But the oil is giving me fits. It is a 5v reference, but I cant get it to do anything but peg the gauge when I fire it up. I picked up 5v off of the IAC, ground to the firewall, and signal to the tach. I'm about ready to use the hole by the filter and put a new sender in.
