G-Body Engine Swap.
Same with my nearest referee station. They were just as CLUELESS
as the DMV.
Boils down to a couple of things:
Also pick up a copy of Mike Knell's book called: Chevrolet TPI/TBI engine swapping .
Although it is for Gen 1 engines, there are sections on emissions in Ca that will be of great use for you.
as the DMV.
Seriously though, I agree with what G-Body said (from what I understand), although I can't give a qualified opinion since I'm not a CA resident.
Here's a free bump hoping a real expert can chime in.
It can be done and has been done. As G-body stated, Class means Truck engine to truck body. Car engine to car body.. you can not use a LQ9 (truck) into a Car body. So the question would be, What does your Registration state it is ? car or truck.
You would be best to get a whole donner car/truck, that way you can get everything you need from the any fuel tank sensors, connector and last bit of wiring.
You can go from one referee station to another and get different view of the laws. You may not pass at one, but another will pass you (providing you have all of the documentation you are asked for). Some have said to just keep going around till you find one that will co-operate and work with you and then pass it.
I just talked to someone who had his Celica upgraded to a later model Turbo engine and it was done by some school in Livermore.
good luck
Even though they class it as a truck for plates, registration etc for emissions they classify it as a car
