Car no start.... please help
You'll only see that 12VDC for ~2sec after you turn the key to <RUN> position with the engine not running.
So...either you're not testing that circuit correctly...waiting longer than the ~2sec to hook up your meter or whatnot...
Or...you have your wiring wrong and the PCM isn't seeing the key switch go to <RUN> position.
Let's start referencing the circuits according to their connector and pin to avoid any more confusion.
C101/E you need to feed ignition-switched 12VDC...so that, as I said, the PCM will see the key in the <RUN> position.
C101/D is 12VDC out from the PCM to the fuel pump relay, it has 12VDC supplied by the PCM for ~2sec when the ignition key is turned to the <RUN> position. That 12VDC pulls the relay, which closes the high-amperage fused 12VDC circuit to the fuel pump.
sounds like your only problem is no power on the pink/black.
after those 2 sec the only thing that triggers it after that is the motor turning over. if there is any rpms on the motor the pcm triggers it.
Btw dude I thought you were talking about the 240sx's blk/pink wire in the f3 plug. that goes in to the 240 relay. not the ls1 pcm one. thanks though i got it now.
C101 Plug
A YEL/BLK Low Coolant Sensor
B PNK Hot in Run and Start (IGN/INJ Bank 2 15A)
C BRN PCM 36 Air Pump Relay Control
D DK GRN/WHT PCM 9 Fuel Pump Relay Control
E PNK/BLK PCM 19 Ignition Positive Voltage for PCM
G ORN PCM 57 Battery Positive Voltage for PCM
H BLK/WHT Ground
K GRY/BLK PCM 53 TCS Spark Retard Signal to Brake Control Module
this pink/black wire your talking about not having power sounds like c101/e. you have to add power to it. it dont get it from everything else.
all in all
1 orange=hot/battery
1 black= ground
5 pinks(counting the one with black stripe. 2 pinks on c100, 2 pinks on c101 and 1 pink on c105)=ign. run to ign, turn key, they get power.
1 green/white on c101/d=fuel pump. or run the fuel pump to battery to make sure it runs, for testing.
1 purple=start position on key. or just tap it to the battery till it starts and take it off as soon as it starts so you know your motor runs.
you need nothing else to hear it run. 1 hot, 1 grnd, 5 ign, 1 starter and ofcourse that flamable stuff.
okay i went out and test the relay right this morning and it didn't come on. then i took my harness all apart and started looking for C101/e and couldn't find it. i could only find 3 and they just ran from the pcm to the engine. i clipped the end off of the one plug i need to find. you said it goes to pcm 19? red or blue? Blue is just pink ignition positive voltage (pin 19) and red has no pin 19. i'm rather confused. my engine is a 2000 and i read pin outs and only pink/black wires is.
-Blue pin 3 injector 3 control
-Blue pin 61 camshaft position sensor reference low.
-the last one i'm not sure of it's not on my pin out list but it was connected at both ends.
quick question. do you have the there plugs coming off the harness?
http://www.dxsoftware.com/magnus/wiring.htm
