need to know coolant temp wire
Old Jul 16, 2007 | 04:21 PM
Dustin@PremierAutosports's Avatar
Default need to know coolant temp wire
does anyone know the wire that is used to send coolant temp signal to gauge?
Old Jul 16, 2007 | 05:14 PM
stealth71's Avatar
The PCM wire for a '99 is the BLUE connector #74 yellow wire. Engine Coolant Temperature (ECT) Sensor Signal. The other is a ground.
Old Jul 16, 2007 | 05:51 PM
as soon as that is hooked up to my factory temp gauge wire the engine dies. on a fbody how does the factory gauge get a signal from the ecu?
Old Jul 16, 2007 | 06:01 PM
Speartech's Avatar
9 Second Club/LS1TECH Sponsor
You can't use the factory coolant temp sensor for a gauge. It is ONLY for the PCM. On a factory F-body the gauge operates from serial data generated by the PCM (that's why they are fairly inaccurate). You'll have to add a sending unit for your gauge.
__________________
91 Z28 LS2 408CI, LS9 Supercharger, LPE GT7 cam, Yank3000, 3450 raceweight.
Latest numbers: 9.71 ET, 141.42 MPH, 1.40 60' , 610 RWHP Mustang Dyno
www.speartech.com
