Fueling Questions for Carb LSX swap
Old Jul 22, 2007 | 01:00 PM
QuickZ28's Avatar
Default Fueling Questions for Carb LSX swap
Well since i already posted in the fueling dept and nobody responded, id figure id try here!
Ok heres the deal. Im swapping a 6.0 carbed into my 82 Z28.
It orginally came w/ Crossfire inj....then shortly after i swtiched to carb using a block pump. Well we all know Lsx dont have em...so
I was wondering if i could still use the intake pump(wire it to run when car is on) and use the stock lines, to a regulator to the engine?
Will this work or will i have to run a elec. pump inline?
Im trying to stay cost efficiant so thats why im wondering if i can use the stock intake....
Thanks!!
Old Jul 22, 2007 | 02:16 PM
classic gary's Avatar
i put a carb'ed small block in a Volvo 262 a while back, using the stock in-tank and external electric fuel pumps the Volvo allready had. I just put a Holley blue regulator before the carb, AND a bypass line before that. I "tuned" the bypass with a holley carb jet. once i got the bypass and fuel pressure worked out it was great, no problems, and kept the carb fed under ALL conditions.
Old Jul 22, 2007 | 02:41 PM
QuickZ28's Avatar
WEll im trying to save as much $$ as possible so i was still wondering if I could Use the the stock intake pump...then a regulator off the stock lines into the carb......b/c the stock intake pump was orginally made for FI which uses 2 times the pressure for carb set ups....Then regulate it into the carb!!
Old Jul 22, 2007 | 03:28 PM
LS1MCSS's Avatar
A card setup will need to run at around 7psi. That will probably be cutting the stock pump back too much. I don't know what that would do to the pump, if you could even cut the pressure back that much, but it can't be good for it.
Old Jul 22, 2007 | 03:37 PM
QuickZ28's Avatar
WEll im gonna try and see how it goes....
Ill try to tune the pressure back and see how it runs.....if all else fails...
ill just get a inline elec. then re run it!
Old Jul 23, 2007 | 04:36 PM
Volvos are fuel injected, they run around 30 psi, run a bypass and a holley blue regulator and you'll be OK.
