have question on ls1 or ls2
Old Jul 23, 2007 | 08:20 PM
brownz's Avatar
Default have question on ls1 or ls2
looking to buy an complete motor swap for my 79z would just like to have some input on if the ls2 from a 06 gto is worth the extra $ or if going with an ls1 from a 2002 f-body is the better idea both with t-56 trans.i know that the oil pan and such need to changed on the ls2 but that is only 250.00 from
gm with my discount not a big deal. so any thoughts on this would be great
thanks any info on this swap into a sec gen camaro would also be helpful
Old Jul 24, 2007 | 05:19 PM
brownz's Avatar
any opinions
Old Jul 24, 2007 | 07:29 PM
Rhino's Avatar
The 06 gto will have slightly better flowing 243 casting heads. I believe it's 6.0L as well. What is your purpose for the car? What kind of HP numbers are you looking for? How much of a price difference have you found them for? If it's simply a decent driver, I would probably go for the cheaper LS1 personally.
Something else I'm not sure about... Is the GTO a cable driven Throttle body or is it electronic? A cable driven will be a simpler swap.
Old Jul 24, 2007 | 08:21 PM
brownz's Avatar
the ls2 is drive by wire as for the price the ls1 is about 4,000$ cheaper. the car is just going to be a well rounded pro-touring street car looking for about 400hp maybe more just not sure if the extra money really does me any good from that stand point of a street car some time strip or autocross?
Old Jul 24, 2007 | 08:26 PM
cherryelky305's Avatar
An Ls1 should be fine for that. They put out 350 HP at the crank, so some simple mods should get you to the 400 mark. And for $4000 less its a easy choice if I were in your shoes.
Old Jul 24, 2007 | 08:27 PM
nobreaks254's Avatar
If you're not looking for big power I would save the cash and get the LS1. Unless money is no object.
Old Jul 24, 2007 | 08:34 PM
brownz's Avatar
money is always an object.
