Mechanical Speedo to 4L60e
Old Jul 25, 2007 | 05:01 PM
kevtherev's Avatar
Default Mechanical Speedo to 4L60e
Can't get anything out of my newly installed Cable-X Box.All wiring ie signal from PCM,ign live and ground connected but not a sign from my sleeping speedo.Any ideas?
Also rev counter recording only half engine speed?
61 Vette,2002LS1,4L60e,C4 Vette rearend.Speartech loom.First of it's kind in merry England!
Old Jul 25, 2007 | 05:05 PM
LS1MCSS's Avatar
Did you follow the instructions about the correct setup procedure. If not, it won't work.
Old Jul 25, 2007 | 05:41 PM
kevtherev's Avatar
Yes,followed set up instructions,all seemed to set ok,LED flashes but nothing else happens.I'm told it's getting a signal so I don't know what 's up.
Old Jul 25, 2007 | 07:29 PM
LS1MCSS's Avatar
It should have run at 60 mph for a few (can't remeber how many) seconds. If it didn't do that, then it's probably defective. Your wiring is,
Red Wire: Hot Wire, Ignition On
Black Wire: Ground
White Wire: Signal from Sensor
