Removing a fan
Old Aug 2, 2007 | 12:47 AM
ryanvv355's Avatar
Default Removing a fan
I am sad to have to ask this question, but here it goes: How do you get the fan off the front of a 6.0?
Old Aug 2, 2007 | 01:48 AM
G-Body's Avatar
sawzall wielding director
With a wrench
I can`t remember for sure but I believe it is a standard thread (left to loosen). The easiest way is to use a strap wrench to hold the water pump pulley, but you can also leave the belt on put a wrench on the nut for the fan and wack the wrench with a piece of wood (2 foot long piece of 2x2 works really well )
Old Aug 2, 2007 | 07:30 AM
1987earthquake's Avatar
I used an air chisel. I put the chisel on the lip of the "nut" and hit the chisel and it broke loose then just twisted it right off.
Old Aug 2, 2007 | 08:13 AM
brentg454's Avatar
What earthquake said...you just need to jar it loose and it comes right off.
Old Aug 2, 2007 | 02:07 PM
ryanvv355's Avatar
Ok guys, I'll give the air chisel a try, thanks.
