Help on converting a 98 harness
Old Aug 11, 2007 | 11:31 AM
69c4x11's Avatar
Default Help on converting a 98 harness
I have all my connectors labled but I need to know which ones that I need to cut out and supply power to etc. Is there any info on the plugs that went inside the car? I have the pinouts but I am still confused on what I need to make it stand alone. The way I under stand is there are 5 or 6 plugs on the 98 harness that I will have to cut off and then use them to supply power to the computer, guages, etc. What wires go where is what I am asking.
Thanks In Advance. Kade
Old Aug 11, 2007 | 12:13 PM
chrisp3's Avatar
You did check the sticky's.... didn't you??
https://ls1tech.com/forums/attachmen...chmentid=73260
ChrisP
