Water Pump question??
Old Aug 20, 2007 | 11:29 PM
1969NovaSS's Avatar
Default Water Pump question??
Ok, Heres what I got. I have a 6.0 out of a 2000 2500 pick up. I am installing a LS1 intake on it for now just to get the motor in the car and fired up. I have a 2000 Z28 Camaro harness converted with ECM. I know the injectors,fuel line and coils are different but I need to find the part number of the newer truck water pump or what kind of veh it is. I want to retain the stock pulley set-up from the truck. I seen a member do this but cant seem to find the thread. Can anyone help?? I do know that the upperneck is relocated off to the side to allow for the L92 intake.
Old Aug 21, 2007 | 11:56 PM
1969NovaSS's Avatar
Ok, seems the answer isnt as easy as I thought. Well what set ups are you using. I just noticed that the Alternator sits kinda high on the truck set up now since I put the LS1 intake on. I am dropping the motor in a 69 Nova. Would the Camaro set up or Corvette be better?
Old Aug 22, 2007 | 12:15 AM
G-Body's Avatar
sawzall wielding director
The water pump PN along with the rest of the parts needed to swap should be in this thread http://www.performancetrucks.net/for...ake+water+pump .
You can run the truck accys, but you will have to buy or make a bracket to relocate the idler pulley.
Old Aug 22, 2007 | 10:42 PM
1969NovaSS's Avatar
Thanks alot. I appreciate it. I looked forever and couldnt find it. Thanks again!!!!
