problem with initial starting.
Old Sep 9, 2007 | 03:21 PM
ls1blazer's Avatar
Default problem with initial starting.
I have fuel pressure, injectors are working but I only have spark at one coil. All the other coils have power also just as the one that works. What else could it be ? The pcm was reprogrammed .
Old Sep 10, 2007 | 07:28 AM
ghettocruiser's Avatar
If you have the correct power at all the coil wires, and one is sparking but the others arent, I would say its either a plug wire, plug, or harness issue. I cant remember if the coils fire per cylinder or if they fire per bank or what.
What harness are you using...who modified it to work...?? Who re-progammed teh PCM and what all did they configure?
Also what year is the motor...and what year is the harness/pcm?
J.
Old Sep 10, 2007 | 08:51 PM
ls1blazer's Avatar
The pcm just had emissions,vats and a few other things deleted. It still has the stock programming .Engine and trans are an 02 lq9.
Old Sep 11, 2007 | 08:09 PM
ls1blazer's Avatar
Found the problem ! The pcm was reflashed with a 02 van vin# . The van only has one coil hence only one coil firing . I got a stock pcm from the salvage yard for a 5.3 and it fired right up !
