cruise control wiring
Some are telling me that I need to have a hot in run 12 volt connection wired in for the system to have power. Does this sound right even though the system is drive by wire and is fully controlled by the pcm?
Thanks
He told me there are are a number of requirements for the cruise to work. He would not divulge the secrets as it took him many many hours to discover the solution.
I would say to get a wireing diagram and study, highlight all the areas you have covered.
Keep us posted.
John
I'm working on a system for using 4th gen TA electric headlight doors on my '68 Camaro. The top picture is of the wiring diagram for the TA, the bottom is how you actually have to wire the control module to get it to work. Wiring the motors 100% "by the book" doesn't work for some weird reason. This one took quite some time to figure out.
Thats why you can wire it to work just like it did in the donor car. All it needs is a few hook ups, power, ground, and the cable and it should work.
The PCM feeds info to it, and I believe it needs to be hooked to the brake light switch, as well as teh clutch switch if your car is a manual. And then however you plan to activate it (stalk switch, custom switch, etc) It seems to be pretty stand alone and really easy to hook up. No vac reference makes it nice too...
J.
