Speartech LS2/6L80E swap
91 Z28 LS2 408CI, LS9 Supercharger, LPE GT7 cam, Yank3000, 3450 raceweight.
Latest numbers: 9.71 ET, 141.42 MPH, 1.40 60' , 610 RWHP Mustang Dyno
www.speartech.com
www.speartech.com
Thanks,
Whit
Thanks,
Whit
It's only $$1,870.96 Not to bad! Don't know if its 2wd or 4wd
Sounds like GM parts direct pricing. Don't forget the Vaseline when they bend you over on shipping.
Also these transmissions have a core charge; they end up being around $3000.
www.speartech.com
@Speartech how much $$$ for only programming the two Computers and Schematicts of the changed wires? LC9 (Revlimmiter set to 6200)- 6L80 Combo
www.speartech.com
Maximum engine power:469 bhp ( 349 kW )
Maximum engine torque: 439 lb-ft ( 595 Nm )
Maximum gearbox torque: 664 lb-ft ( 900 Nm )
6l90
Maximum engine power: 452 bhp ( 337 kW ), Diesel: 300bhp ( 223kW )
Maximum engine torque: 531 lb-ft ( 720 Nm ), Diesel: 520 lb-ft ( 705 Nm )
Maximum gearbox torque: 885 lb-ft ( 1200 Nm )
The diesel ratings are for the new 4.5L due out in 09-10 for the hummer H2 and 1500!
i am guessing there are not interchangible parts between these and the 4l80's
what is the limiting factor in these as far as breakage? input shafts?
what is it going to take for one of these to live behind 1khp/tq - 800hp/tq ?
Does anyone have a part number for the 58x cam sensor?
Is the new cam sensor a direct replacement or do I need to replace the cover as well?
Are rest of the sensors compatible?
What do I do for a shifter with this thing?
Thanks,
Whit
Thanks,
Whit
I don't know how many of the sensors will interchange, but I do know that changing the reluctor wheel will require some skills and a few special tools. BTW you might look into the new harness kit that GM just started selling to control your setup. It's p/n:19166568 for the x58 LS2's and it comes with computer, harness, o2 sensor's, and the throttle pedal. I'm not 100%, but it looks like a E67 ECU and the best part is they are only $815 from Scoggins Dickey.
I ordered one two days ago as soon as they were available. I don't know if the E67 would be able to control the tranny though so maybe your stuck with the E38..... I am working on a 06 Solstice project and picked up a 6L80E and will be dropping in a 650hp na LS7 or LS3/L92 (Still deciding). Original config was a 4cyl. So whats my cheapest option for adapting the wiring harness and the right controller for the LS/6L80E?
