Looking for ways to build a quiet exhaust?
Old Oct 6, 2007 | 10:20 AM
philntx's Avatar
Default Looking for ways to build a quiet exhaust?
Found this while surfing.....
http://www.norcal-saac.org/ot/soundadvice.htm
Old Oct 8, 2007 | 03:03 PM
b005td's Avatar
sounds like that website is advertising for Flowmaster tho
Old Oct 10, 2007 | 10:16 PM
Quick Double Nickel's Avatar
One thing not mentioned in the article was the number of bends in the pipe. The more bends you have in the exhaust pipe the quieter it will be. So putting in an X-pipe, routing it to the mufflers (I don't necessarily believe they need to be offset, but it probably helps a bit), then routing them over the axle and back down, then angling them towards the rear corners of the car should make it pretty quiet. Putting as many bends as you can will help and it shouldn't hurt the power all that much if you use mandrel bends.
One of the loudest (and most annoying) cars I ever heard was an early RX-7 with a rotary with a straight pipe coming off the headers all the way to the back. No bends at all, just straight. I think the pipe actaully made it louder than just headers alone (probably gave the little motor some extra power too).
Old Oct 10, 2007 | 10:50 PM
lt4malibu's Avatar
exactly what i was gonna say...
plus using some "normal" mufflers doesnt hurt, and for guys that dont run tail pipes - turndowns faced towards eachother slightly reduce the noise(cancels eachother out and they dont deflect diretly off the ground)
Old Oct 11, 2007 | 05:18 AM
forcd ind's Avatar
its hard to have a freeflowing ex. and quiet too-i had 40's, 3", no x-pipe on my chevelle (489 w/supercharger) it was nasty after a short drive, even with full exhaust system-i switched to 50's (suv style) and added a x-over pipe, made a big improvement, but i could feel the power loss
one thing i wanted to try was some inserts, called car chemistry, they had a couple styles, one went in the collectors, the other i could slip in the tailpipes, pull out when i wanted, but they were pricey-but if they did the job, would have been worth it
By Brett Foote | 2026-06-04 05:00:17
