Newbie here.. please help with wiring question
The TCC goes and connects to a relay which is ran off the brake pedal, and the Positive (orange wire) connects to the hot side of the starter, and the IGN (pink) goes back to the ignition switch... Is this correct? What do i do with the other wires, as we aren't running a Tach. Also what about the TPS, is that for a cruise control, which we aren't running either.
Thanks for your help, I am still a newbie at wiring, so any help would be excellent.
Thanks again
- Andy
Thanks.
- Andy
The TPS should have three wires and the correct plug with to go on the Throttle Position Sensor. Maybe the VSS got tagged TPS by mistake. The guy that did the harness sure would be the one to ask. As you mentioned the Bat is 12V positive (always hot) the Ign goes to the ignition switch 12V positive (when key on) Tach is pulsed signal for rpm. The Tcc is release for converter and gets 12V positive when brake is released (opposite of brake lights) While you can use a relay ect and your old brake switch a later 79 and up GM plunger switch will give you the needed output. they are about $6 at most any parts store and you dont have to monkey with a relay and additional wiring.
If the other wire is VSS it is a pulsed signal with vehicle speed value. You can get a adapter to hook a cable speedo to it.
