Hot Rod Rule Change
Old Oct 21, 2007 | 10:48 AM
Orangepeeler's Avatar
Default Hot Rod Rule Change
Need some help here guys! I started a thread at Hot Rod.com about reducing the minimum weight requirement so that ANYONE that has an LS1 conversion that doesn't weight 3300 lbs. might be able to run. If this is interesting to you, go ove and help me out. Here's the link:
http://forums.hotrod.com/70/6425599/...ule/index.html
Thnaks, Mike.
Old Oct 21, 2007 | 11:29 AM
QSPres's Avatar
Easier and much, much better to add balast than to try to make everyone weigh less...
Suck it up and deal..
Old Oct 21, 2007 | 01:47 PM
Matt D's Avatar
Retired Street Racer
That's what happens when you do a race or class like that. Not to be a dick, but deal with it or don't race in it. There are plenty of other events that you could do that don't limit you on weight.
Old Oct 22, 2007 | 07:10 AM
LS1GMCTruck's Avatar
Question Hmmm...
You'd like to race your LS1 car, that is 500 lbs. lighter than the minimum required. If a competitor with his version of an LS1 car wanted to race you, that weighed 1000 lbs lighter than the minimum required, what would your mindset be then?
Old Oct 22, 2007 | 12:06 PM
'JustDreamin''s Avatar
Best way to add 500lbs of ballast would be to add a 2nd LS1!!! Wouldn't that catch those pesky Hot Rod guys off guard....
Seriously, they've got a minimum weight because they want to keep budgets down. Getting weight out usually costs money, so keeping the minimum reasonable for a factory built platform with iron block and heads keeps cost under control (and keep cars practical).... I don't think sprint cars have a minimum weight, which is why they're built so light, have no battery or starter, cost a fair bit, and have ridiculous power to weight ratios.
'JustDreamin'
Old Oct 22, 2007 | 03:27 PM
Don Lindsey's Avatar
You're lucky that your car's already under the minimum weight!! My Drag Radial car is about 200lbs OVER weight for it's class and that's going to be an expensive 200lbs if I decide to try to take it off the car. At least you can put the weight wherever you want to make the car work!!
