LS1 Cruise Control vs Universal
Old Jun 16, 2003 | 11:44 AM
Fastlane68's Avatar
Default LS1 Cruise Control vs Universal
Has anyone installed a cruise control on an LS1 (in a non-LS1 vehicle)? Did you use the stock LS1 cruise control module or one of the universal cuise control kits? Any advantage one way or the other?
Old Jun 16, 2003 | 04:23 PM
Coolvet's Avatar
Default Re: LS1 Cruise Control vs Universal
I have just installed the Rostar unit from Ididit, but I haven't hooked it up yet to see if and how it works.
Old Jun 16, 2003 | 04:44 PM
LS1 PWRD's Avatar
I used the stock cruise control from my Astro AWD. Built new bracket for servo. Shortage of under hood space was the reason. Didn't like to mount the LS1 servo under the van.
Old Jun 16, 2003 | 07:26 PM
Speartech's Avatar
9 Second Club/LS1TECH Sponsor
I like the factory units. If you have a factory service manual to hook up the wiring, the GM unit is unmatched by any aftermarket unit as far as precision and reliability go.
On top of that, they are on practically every GM car since around 1991, so the junkyards are FULL of them just begging to be put back in use!!
Order a non-TCS cruise control cable from an LS1 F-body, and you're ready to go.
This assumes of course that you are using a GM type of steering column with the late model cruise switch in it (ON/OFF, SET/COAST, RESUME/ACCEL).
__________________
91 Z28 LS2 408CI, LS9 Supercharger, LPE GT7 cam, Yank3000, 3450 raceweight.
Latest numbers: 9.71 ET, 141.42 MPH, 1.40 60' , 610 RWHP Mustang Dyno
www.speartech.com
Old Jun 19, 2003 | 02:16 AM
gEtyOPaPiOn's Avatar
Anyone has the wiring diagram to hook up the LS1 cruise control ? thanks
1969 CAMARO RS SS PROJECT
