Gauge panel install questions
Old Nov 13, 2007 | 02:32 AM
djquik88's Avatar
Default Gauge panel install questions
I'm wanting to hook up a 98 F-body instrument panel in my 92 Mustang. I have a Speartech harness with the VSS,Tach, Water temp and Oil pres. signal wires pulled out of the PCM. Beside those 4 wires, can anyone tell me what else needs to be connected (pin #)to the instrument panel to get the gauges to work correctly?
BTW, it is a 98 harness and PCM.
Old Nov 13, 2007 | 02:26 PM
lt4malibu's Avatar
here's the pinout:
Pin
Wire Color
Circuit No.
Function
A1
PNK
39
Power feed from gages Fuse 9
A2
DK BLU
1936
Fuel gage signal
A3
GRY
728
SECURITY indicator lamp control
A4
BRN/WHT
419
SERVICE ENGINE SOON indicator lamp control
A5
PNK
39
A6
YEL/BLK
68
Low coolant level indicator control
A7
BRN
358
AIR BAG indicator control
A8
PPL/WHT
1572
TCS OFF indicator control (with NW9)
A10
TAN/WHT
33
BRAKE warning indicator lamp control
A11
LT GRN
11
High beam headlights on
A12
PPL/WHT
237
FASTEN SEATBELT indicator lamp control
A13
ORN
640
Power feed from PWR ACCY Fuse 7
A14
RED
225
Generator output indicator control
A15
BRN/WHT
1173
Oil level lamp signal
A16
DK BLU
1537
LOW TRAC indicator lamp control
A17
DK GRN
135
Coolant temperature sensor signal
B1
BRN
9
Odometer illumination
B2
GRY
8
IP illumination lamps feed
B3
BLK
650
Ground
B4
WHT
375
SKIP SHIFT indicator lamp control (V8 only)
B5
DK BLU/WHT
1415
Right turn signal switch output
B12
DK GRN/WHT
817
Vehicle speed signal-4000 pulses per mile
B13
WHT
121
Tachometer signal
B14
LT BLU/WHT
1414
Left turn signal switch output
B15
BLK/WHT
451
Ground
B16
TAN
31
Oil pressure indicator control
B17
LT GRN
867
ABS fail signal
