lt1 to ls1 battery hookup questions
Old Nov 14, 2007 | 11:52 AM
95GreenZ28's Avatar
Default lt1 to ls1 battery hookup questions
Ok where do I need all the wires to go to? One goes from the battery to the distribution block for sure. Do I need a wire going from the battery to the starter? What size of wire do I hook the alternator up with? Thanks in advance guys!
Old Nov 14, 2007 | 11:58 AM
LS198Z28's Avatar
yes, you need a battery wire going to both the starter and to the alt. 2 or 4 guage wire should be fine. if you have a sound system you might want to go bigger.
Old Nov 14, 2007 | 12:28 PM
95GreenZ28's Avatar
Ok so the 3 wires coming off my positive cable should go to dist block/starter/alternator. Thats it? And the ground should ground on the block and the frame correct? Thanks for your help!
Old Nov 16, 2007 | 10:51 PM
ex-SS-ve's Avatar
i just used the factory lt1 cables on mine. and lengthened the alternator feed.
Old Nov 17, 2007 | 11:39 AM
95GreenZ28's Avatar
Thanks man!!
