LS1 VSS OUTPUT WIRE FOR SPEEDOMETER
Old Jun 19, 2003 | 04:13 PM
gEtyOPaPiOn's Avatar
Default LS1 VSS OUTPUT WIRE FOR SPEEDOMETER
hello i have a 1969 camaro with an LS1 AND 4L60e and im wondering where should i connect the speedometer signal too ? tail of trans or pcm output ? and what color wire ? for tail and pcm thanks
Old Jun 19, 2003 | 07:50 PM
86MonteSSLS-1's Avatar
Default Re: LS1 VSS OUTPUT WIRE FOR SPEEDOMETER
Hook it to output of tranny, (purple one I think)
Old Jun 19, 2003 | 08:34 PM
Lesrace82's Avatar
If your using an autometer speedo, its gonna need the raw signal coming from the tranny to work properly. Then a problem I ran into that I havent read on here from anybody else is, that when I hooked the speedo up the tranny, it wouldnt shift. I had to install a 2.2K resister in the line and just tap into the VSS wire. Dont run it to the speedo and then to the PCM.
Old Jun 24, 2003 | 06:35 AM
67ls1CamaroProject's Avatar
I have the T56 with the autometer speedo and I took the VSS from tranny to the speedo and the signal out of speedo back to PCM. Works fine, but I shift manually of course.
