can you bypass the vats?
Old Nov 24, 2007 | 09:54 AM
leonpiper69's Avatar
Default can you bypass the vats?
i just want to get my engine runnin and it still has the vats programmed into the computer. if i just run the fuel pump off an igniton hot source, it should run no? i thought the vats justkept the ecu from turning on the fuel pump, or is there more to it?
Old Nov 24, 2007 | 10:00 AM
Schitzo's Avatar
I doubt that will work. As I understand it, the VATS disables the injector pulses so the pump might be bringing in fuel but the injectors won't shoot it in.
Old Nov 24, 2007 | 10:09 AM
Ravant's Avatar
Yeah - it'll disable the injectors as well as the pump. You'll have to get a VATS bypass unit, or a simulator.
Old Nov 24, 2007 | 11:44 AM
WJ MARK's Avatar
12 Second Truck Club
If you have HPT you can turn off the Vats. Had to do it on a buddies obs truck when we swaped a newer motor in.
Old Nov 24, 2007 | 11:53 AM
im going to keep the vats. imgoing to build one of those signal generators, i just wanted to get it running. today im just runnin my fuel lines, i probably wont get to try to fire i today. i just came in the house to call advance to have them deliver some parts.
Old Nov 27, 2007 | 10:56 AM
72Elkytpi's Avatar
Should be a plug for installing a bypass on your harness. Atleast my old 98 S&P harness had it.
