LT1 into a Fox body, anyone done it?
Old Dec 7, 2007 | 02:16 PM
FASTFATBOY's Avatar
Default LT1 into a Fox body, anyone done it?
Hard to find any info on this. I need a wiring harness to support a 4L60E and factory ecm.
David
Old Dec 7, 2007 | 04:04 PM
zigroid's Avatar
I haven't done it, nor do I have plans to do it, but an LT1 bolts in place of a SBC and SBC swaps have been done quite a few times. the wiring harness is just a matter of finding someone that has one.
Old Dec 7, 2007 | 04:59 PM
95GreenZ28's Avatar
let me know if you need any lt1 parts as well man
Old Dec 8, 2007 | 02:42 PM
adamt's Avatar
Default fox swap
i put a ls1 into a 89 coupe, i used a qa1 k member and fabed my own mounts that go to the k member, i modified the original double hump trans mount, did not have to do anything to the drive shaft other than change the yoke to fit the 4l60e, the onky thing that i am trying to get now is some long tube headers that can fit., i used a factory harness with a 99 comp that was for a 4l60e and sent it to speartech and they fixed it up for me. If you have any Q's ask away.
Old Dec 8, 2007 | 03:46 PM
97'-lt1's Avatar
adamt - so you used the factory mustang trans cross member? If so what changes did you have to do?
